Markofon M37
Utende
Markofon M37
Příspěvek od Utende »
Hi everybody,
I am an Italian collector, I have a 4 valves Markofon M37, but no scheme.
Can somebody help?
Thank you in advance!
ranlos
Re: Markofon M37
Příspěvek od ranlos »
Prohledal bych tyhle stránky a možná by to mohlo být totožné s jiným schématem http://www.oldradio.cz/
Re: Markofon M37
Příspěvek od jirka5 »
Hallo Utende,
It is probably not Markofon M37, but only M371. The scheme is on the Czech website, but it is not possible to send it directly to the link. I send you a link to the page with pre - WWII Czechoslovak receivers. There you will find the schemes of Markofons.
http://www.oldradio.cz/rad20.htm
ranlos
Re: Markofon M37
Markofon M37 a M371 jsou dvě rádia
Utende
Re: Markofon M37
Thank you Ferito and Jirk5, I will start my research in oldradio.cz.
However, as Ferito adviced, M37 and M371 are completely different, having M37 only 4 tubes (AZ1, AL4, TAF7 e AF3), whilst M371 has 5 tubes, they have only the AZ1 in common.
In any case, if someone has a scheme with the same 4 tubes (AZ1, AL4, TAF7 e AF3) may be very useful.
ranlos
Re: Markofon M37
Tady je odkaz na rádia se stejnýma elektronkama třeba bude něco podobné? https://www.doctsf.com/grandlivre/prese ... F7,AL4,AZ1
