Markofon M37
Napsal: 16.10. 2023, 21:48
od Utende
Hi everybody,
I am an Italian collector, I have a 4 valves Markofon M37, but no scheme.
Can somebody help?
Thank you in advance!
Re: Markofon M37
Napsal: 17.10. 2023, 18:35
od ranlos
Prohledal bych tyhle stránky a možná by to mohlo být totožné s jiným schématem
http://www.oldradio.cz/
Re: Markofon M37
Napsal: 17.10. 2023, 18:53
od jirka5
Hallo Utende,
It is probably not Markofon M37, but only M371. The scheme is on the Czech website, but it is not possible to send it directly to the link. I send you a link to the page with pre - WWII Czechoslovak receivers. There you will find the schemes of Markofons.
http://www.oldradio.cz/rad20.htm
Re: Markofon M37
Napsal: 18.10. 2023, 15:32
od ranlos
Markofon M37 a M371 jsou dvě rádia
Re: Markofon M37
Napsal: 21.10. 2023, 21:19
od Utende
Thank you Ferito and Jirk5, I will start my research in oldradio.cz.
However, as Ferito adviced, M37 and M371 are completely different, having M37 only 4 tubes (AZ1, AL4, TAF7 e AF3), whilst M371 has 5 tubes, they have only the AZ1 in common.
In any case, if someone has a scheme with the same 4 tubes (AZ1, AL4, TAF7 e AF3) may be very useful.
Re: Markofon M37
Napsal: 22.10. 2023, 13:30
od ranlos
Tady je odkaz na rádia se stejnýma elektronkama třeba bude něco podobné?
https://www.doctsf.com/grandlivre/prese ... F7,AL4,AZ1
